Index ¦ All posts
RSS reader with RegEx matching and push notifications
Estimated read time: 3 minutes
Many years ago I made an awful bash script which subscribed to a couple of RSS feeds and pushed notifications to me if it found keywords of value in the title. In the event doing some changes, I made the jump to python. Here is the gist of it, where you easily can substitute the choice of database and mobile push service. I use pushover (which cost a couple of dollars, but well worth it) and sqlite3.
#!/usr/bin/python3
import feedparser # pip3 install
import http.client
import os
import re
import sqlite3
import sys
import urllib
sqlite_db_file = '/home/user/.rss-reader.db'
pushover_token = 'xxx'
pushover_userkey = 'xxx'
feeds = [
        'name': 'Lokalavis 1',
        'url': 'http://lokalavis.no/rss.xml',
        'keywords': ['.']
        'name': 'Aftenbladet',
        'url': 'http://www.aftenbladet.no/rss',
        'keywords': [
            'Ryfylke',
            'Lokalt sted 1',
            'Lokalt sted 2',
            'fly(plass|krasj|ulykke)',
            'ryfast',
            'skogbrann'
        'name': 'Reddit Frontpage',
        'url': 'https://www.reddit.com/.rss',
        'keywords': ['norw(ay|egian)']},
        'name': 'Reddit Linux',
        'url': 'https://www.reddit.com/r/linux.rss',
        'keywords': ['debian', 'vim', 'lwn', 'stallman']
         'name': 'HackerNews',
         'url': 'https://hnrss.org/frontpage',
         'keywords': [
             'postgres',
             'norw(ay|egian)',
             'debian',
db = sqlite3.connect(sqlite_db_file)
c = db.cursor()
create_table = '''CREATE TABLE IF NOT EXISTS entries (
                    id INTEGER PRIMARY KEY AUTOINCREMENT,
                    url TEXT,
                    summary TEXT
c.execute(create_table)
db.commit()
def tty():
    return os.isatty(sys.stdin.fileno())
def save_in_db(url, summary):
    c = db.cursor()
    insert = "INSERT INTO entries VALUES (NULL, ?, ?);"
    c.execute(insert, [url, summary])
    db.commit()
def link_in_db(link):
    c = db.cursor()
    c.execute("SELECT * FROM entries where url = ?", [link])
    if len(c.fetchall()) > 0:
        return True
    return False
def push(title, summary, link):
    conn = http.client.HTTPSConnection("api.pushover.net:443")
    conn.request("POST", "/1/messages.json",
      urllib.parse.urlencode({
        "token": pushover_token,
        "user": pushover_userkey,
        "title": title,
        "message": summary,
        "url": link
      }), { "Content-type": "application/x-www-form-urlencoded" })
    conn.getresponse()
for feed in feeds:
    if tty(): print("Fetching {}".format(feed['url']))
    p = feedparser.parse(feed['url'])
    for entry in p.entries:
        link = entry.link
        summary = entry.summary
        for keyword in feed['keywords']:
            if re.search(keyword, entry.summary) and not link_in_db(link):
                if tty(): print("Keyword hit '{}' in {}".format(keyword, entry.title))
                push_title = "{} ({})".format(feed['name'], keyword)
                title_and_summary = "{} - {}".format(entry.title, entry.summary)
                push(push_title, title_and_summary, link)
                save_in_db(link, title_and_summary)
Add to cron:
*/10 * * * * /home/user/bin/rss-reader.py
Profit!
I have added the field summary in my database for possible later use.
Here is a screenshot of the Pushover telling me the local ferry is having trouble. (-:
pushover
© Torvald Tåke. Built using Pelican. Theme by Giulio Fidente on github.
